It is currently Fri Jul 11, 2025 7:57 am
PostPosted: Thu Apr 04, 2019 3:04 pm
Hi folks
Have measured up the current end float at .28mm , I think that’s 11 thou.
Is typical about 5?
Would you recommend I replace the brass spacer ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Apr 04, 2019 3:27 pm
Simon,
Vizard in "Modify your Mini" says endfloat should be between 0.0035" and 0.0065", aim for lowest limit in the interest of minimum gear noise.
Matt Read sells spacers of varying thickness so you can set the correct clearance. Also check the condition of the outer thrust washer and the "C" ring, as they are prone to wear which increases endfloat.
Clive
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Apr 04, 2019 3:30 pm
Thanks Clive
I’ll look into this .
I just remembered I also have your flywheel puller still !
Simonw
Brisbane QLD
- 1969 Mini K
