It is currently Sat Jul 12, 2025 12:48 pm
 Post subject: Bore size
PostPosted: Thu Mar 21, 2019 6:10 pm
I measured the bore at approximately 71.5 on a 1275 block what size is it 1293 , 1310 etc
 Post subject: Re: Bore size
PostPosted: Thu Mar 21, 2019 6:25 pm
71.5mm is 2.815" which is 35 thou over standard 2.780". 40 thou over is 1310cc
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Mar 21, 2019 7:34 pm
Thanks so it is probably 1310.
PostPosted: Fri Mar 22, 2019 2:47 pm
Measured mine today at 71.3mm which I worked out to be 1297cc.
PostPosted: Sat Mar 23, 2019 4:37 pm
Even better !!
