It is currently Sun Jul 13, 2025 1:31 am
PostPosted: Mon Dec 03, 2018 5:33 pm
Hi All,
Am trying to remove the front hydro bag to check it but cant get it out past the frame, everything is undone/removed, just cant get it out of it "hole" any trick to this?
PostPosted: Mon Dec 03, 2018 5:49 pm
Hi Asuth
Have you removed the retainer plate that holds it steady, it's easy to miss.
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Mon Dec 03, 2018 7:25 pm
is it loose? if it seems like it's rock solid, then rotate it, they have lock tabs holding them in
tapping with a soft face hammer while rotating will shake it loose
PostPosted: Mon Dec 03, 2018 7:31 pm
Yup got it all loose just couldbt get it out past the subframe. Looks like it has had an extra piece welded to the subframe for what reason i do not know.
PostPosted: Mon Dec 03, 2018 7:51 pm
you sure it's welded? as Dave said, there's another little upside down L shaped bracket thats held on with 2 screws
PostPosted: Tue Dec 04, 2018 6:20 am
Is this the bracket? On the in side?
PostPosted: Tue Dec 04, 2018 6:32 am
Yes, that's the one-should be held on with two screws
PostPosted: Tue Dec 04, 2018 6:39 am
Cool. Ok I think the screws have been put in the wrong side? Otherwise how the hell do you get to them haha
PostPosted: Tue Dec 04, 2018 11:44 am
that's why we have stubby screwdrivers or screwdriver bits that go into a socket wrench adapter
PostPosted: Tue Dec 04, 2018 5:39 pm
Got it! So simple :oops:
Thanks guys
Users browsing this forum: harryjoaquin and 101 guests
