It is currently Sun Jul 13, 2025 8:42 am
 Post subject: Brake Line Setup
PostPosted: Fri Nov 30, 2018 11:19 am
Restoring my project at the minute and the time has come to sort out the brakes.
Looking at the Tandem setup as i have a 5 way proportioning valve and was told it would be the best way to go some time ago.
One question i have is to do with the plumbing of the valve, Im not sure where the 5th valve to the top of the unit is supposed to go?
Apologies if this a silly question, but its one worth asking.
Thanks in advance for your help.
Nick
 Post subject: Re: Brake Line Setup
PostPosted: Fri Nov 30, 2018 2:17 pm
I thought that was was where the brake light switch goes on some cars?
PostPosted: Fri Nov 30, 2018 3:06 pm
2 inlet ports point up
3 outlet ports face down , single one rear brakes , two side by side to front brake hose's
