It is currently Sun Jul 13, 2025 5:26 pm
 Post subject: No Handbrake Turns?
PostPosted: Sat Sep 22, 2018 4:20 pm
I've adjusted the handbrake and fitted sticky semi-slicks but now it doesn't lock the wheels. Why is it so? Is it because the handbrake lever is now too low?
 Post subject: Re: No Handbrake Turns?
PostPosted: Sat Sep 22, 2018 4:35 pm
I would go thru the adjustment procedure again...if you have replaced the cables, they could be off a van??
PostPosted: Sat Sep 22, 2018 6:39 pm
What is the adjustment procedure? I just adjusted at the handbrake lever.
PostPosted: Sat Sep 22, 2018 7:58 pm
Do you have good brake shoes? New?
Drums are within internal diameter size spec?
Have you adjusted the shoes so that they just allow the wheels to turn?
Then you adjust the handbrake
But First!!! Get hold of a Workshop Manual :idea:
PostPosted: Sat Sep 22, 2018 9:04 pm
How to adjust drums
https://youtu.be/M02bqqNOlkY
How to adjust the handbrake (on a later car but the principle is the same)
https://youtu.be/9CkBUnAh9bs
PostPosted: Sat Sep 22, 2018 10:29 pm
Sticky tyres makes it harder to lock the rears.
PostPosted: Sun Sep 23, 2018 11:59 am
and Morrie should know :!: :shock: :lol:
PostPosted: Sun Sep 23, 2018 7:58 pm
As all said above.
However someone (Simon K?) said there are 2 different length handbrake arms, I'd go find a pair of long ones or get the welder onto yours.
PostPosted: Mon Sep 24, 2018 1:08 pm
As all said above.
dunno about different lengths, but I did lengthen mine... added 20mm or so to the end of the arms and then redrilled. Better than stock, but nowhere near as good as hydraulic
PostPosted: Mon Sep 24, 2018 5:46 pm
I think your real issue is "fitted sticky semi-slicks"....
IME, the best khana tyres ...for the rear... are the baldest 145s you can find ..inflated to around 50psi....
Cheers, Ian
PostPosted: Mon Sep 24, 2018 9:15 pm
simon k wrote:
As all said above.
:idea: I seem to recall big wheel Moke arms are longer maybe?
Users browsing this forum: BBY755 and 81 guests
