It is currently Sun Jul 13, 2025 7:31 pm
 Post subject: Power output
PostPosted: Tue Aug 07, 2018 7:51 am
Hi all just had an engine done and was wondering what sort of power I would get from it at the wheels. It's a 1275 20thou over light head work and 1:5 roller rockers 45 weber?
 Post subject: Re: Power output
PostPosted: Tue Aug 07, 2018 10:37 am
Depends on what dyno, all are different. Mine made 76HP ATW on a Dyno Dynamics with an RE13 cam, and 86.6 with the RE282. See other specs below.
But my head has big valves and ports, and the Redline manifold I spent 9 hours porting.
PostPosted: Thu Aug 09, 2018 3:51 pm
Like the good Doc says, it's very hard/ impossible to compare numbers from different dyno's in any meaningful way. For what it's worth (not much!), my engine which is more modified than yours, has a number of 75 Hp at the wheels at a place I would not recommend or go to again!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Aug 09, 2018 4:01 pm
At a guess - 50 to 55
An 80 BHP engine has about 50 Hp ATW.
PostPosted: Fri Aug 10, 2018 2:12 pm
What was a standard Cooper S at the wheels?
67 Deluxe
Dry suspension
PostPosted: Fri Aug 10, 2018 2:13 pm
From Memory 45 HP ATW, 78 HP at the flywheel.
I will do a search on here to see if there is any past discussions.
PostPosted: Fri Aug 10, 2018 2:34 pm
There is a bit about drive train loss here- viewtopic.php?f=2&t=66127&p=766424
Users browsing this forum: Bing [Bot] and 88 guests
