It is currently Sun Jul 13, 2025 7:26 pm
PostPosted: Wed Nov 03, 2010 7:41 pm
Supercharged
read a few old posts but didnt find the info i was looking for,
I need to install one on my rover mini to pass compliance, and i was wondering what other people have in their rover minis, or even the 77,78 leylands.
what i have already is the little light that sits in the top crash panel out of a 77 mini s wreck, but someone already pilfered the switch so i dont know what i'm looking for.
pics would be greatly appreciated,
thanks!
PostPosted: Wed Nov 03, 2010 7:45 pm
I don't have one that I can take a picture of straight away but it is just like a door light switch with a little bracket to hold it under the edge of the handbrake lever.
PostPosted: Thu Nov 04, 2010 7:19 am
.... and you wire it by picking up a switched and fused active wire to one side of the globe, and the other side of the globe goes to the switch which earths it to the body when closed.
PostPosted: Thu Nov 04, 2010 11:49 am
This is the switch installed as part of SPO41 (Police specification MK II S). The switch is a Linread, same as a Mini roundnose door switch and the holder and tab are fabricated.
PostPosted: Sat Nov 06, 2010 4:55 pm
Mods rock!
The 1275 LS was the same as this set up (from a 1978 Clubbie S)
PostPosted: Sat Nov 06, 2010 6:02 pm
Supercharged
thanks everyone that helps alot
PostPosted: Sun Jul 22, 2012 8:45 pm
My handbrake light stopped working im not getting power at the light . Is there ment to be power going to the switch? Were does it pick up power from?
Cheers Dan
PostPosted: Sun Jul 22, 2012 8:56 pm
No power to the switch.
One side is earth from the body connection and the main wire/lead goes to the lamp and the other side of the lamp then goes to power via a fuse.
Maybe your globe is blown?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jul 22, 2012 9:00 pm
Im not sure was working up untill handbrake braket broke. Ive checked power and earthed the switch im getting nothing. Should the fuse be in engine bay or in the wiring behind the gauges?
 Post subject: Re:
PostPosted: Sat Aug 04, 2018 5:12 pm
Is this switch used on any other Mini models and is there a part number.
 Post subject: Re:
PostPosted: Sat Aug 04, 2018 7:57 pm
Cheers Dan
I'm not sure if you are talking about a roundnose mini or later. For police spec. roundnose switches like winabbey has shown, the power is picked up from the voltage stabiliser/regulator unit mounted on the speedo housing at B (battery) terminal, then to the warning light and earths at the Linread switch to body.
PostPosted: Sat Aug 04, 2018 9:20 pm
The handbrake switch would be a good interior door light switch replacement. So if there is a part number I could research it.
PostPosted: Sat Aug 04, 2018 9:42 pm
https://minikingdomonline.com.au/produc ... ht-switch/
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
