It is currently Tue Jul 15, 2025 5:20 am
PostPosted: Sat Apr 07, 2018 12:35 pm
Hello All,
Has anyone changed the switch plate on the assembly looks like you cant even take the brushes out. I want to change the switch plate because 2 of the copper prongs have nearly worn away 1 is ok .Looks like you have to cut and join the wires.Would a small amount of solder on the ends be ok? Not sure how long the solder would last as it may wear quickly.
P7676
PostPosted: Sat Apr 07, 2018 2:19 pm
Hi Allen We deal with lead free solder at work now .We hate it as it has higher melting point Doesnt flow as well and I assume harder .We have a roll of it and hate the stuff.
PostPosted: Sat Apr 07, 2018 3:50 pm
Where are you? I think I have a couple around. Your are talking about the brass ring plate that fits to the nylon gear wheel?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Apr 07, 2018 6:13 pm
Are you talking about the brass fingers? A replacement part is available from various Mini suppliers.
https://minikingdomonline.com.au/produc ... er-motors/
