It is currently Tue Jul 15, 2025 7:42 pm
 Post subject: Crownwheel & Pinion
PostPosted: Tue Feb 27, 2018 7:36 am
I have several crownwheels marked 17/62.
Is it ok to match an 18 tooth pinion with the crownwheel mark 17/62?
If not why not?
 Post subject: Re: Crownwheel & Pinion
PostPosted: Tue Feb 27, 2018 7:43 am
No.
Because the 18T pinion is bigger diameter. The 62T crown wheel that belongs with it is slightly smaller than yours, and a different part number.
Pinions are interchangeable, but crown wheels are specific to one ratio.
PostPosted: Tue Feb 27, 2018 9:31 am
If the 62T crown wheel has no identifying marks, how do you ID it as being an 18/62 crown wheel?
PostPosted: Tue Feb 27, 2018 2:32 pm
Part number is stamped near the bolt holes. 22A 411.
The one that goes with a 17T pinion is stamped 22G940.
PostPosted: Tue Feb 27, 2018 2:35 pm
If there isn't a stamped number visible is there a physical way of identifying the crown wheel be it 22G940 or 22A411.
PostPosted: Tue Feb 27, 2018 4:22 pm
I've worked it out guys. The 18/62 diameter is less than the 17/62 crown wheel.
PostPosted: Tue Feb 27, 2018 6:23 pm
PostPosted: Sat Mar 03, 2018 9:25 am
Moving on.
Which model BMC/Leyland front wheel drive cars used the 18/62 diff ratios?
PostPosted: Sat Mar 03, 2018 9:37 am
In Australia- 1275 Cooper S, Clubman GT, and most Minis using the rod change box.
PostPosted: Sat Mar 03, 2018 11:34 am
Very common, most of my collection of bits have the 3.44 ratios.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Mar 03, 2018 11:59 am
Which model BMC/Leyland front wheel drive cars came out of the factory using the 18/62 diff ratios?
PostPosted: Sat Mar 03, 2018 5:21 pm
I answered your question above. Add any Clubman style Mini with a rodchange box including Mini S, Mini SS, 998LS, 1275LS.
Were not used on Morris 1100S cars.
PostPosted: Sat Mar 03, 2018 5:28 pm
Just moving on, - I noticed that the crownwheel I refitted this arvo was stamped 18/62 on two sides, so it could be obvious?
Users browsing this forum: No registered users and 112 guests
