It is currently Tue Jul 15, 2025 8:37 pm
 Post subject: Dip Stick Mk2 Cooper S
PostPosted: Fri Feb 23, 2018 10:47 am
As the picture says, is this hard rubber part replaceable and what is the part number and where can I get one. Is is loose in the tube and rattles and does not seal well.
PostPosted: Fri Feb 23, 2018 11:27 am
Do a Google search on "soften old hard rubber" and you'll find a lot of hits showing methods to soften old brittle rubber items on motor bikes, cars, etc. Basically it involves the use of a mixture that includes wintergreen oil.
To answer your question, I'm not aware that the rubber part is available separately.
PostPosted: Fri Feb 23, 2018 12:20 pm
Methyl salicylate which is the smelly stuff in sports rubs ie deep heat, metsal etc
PostPosted: Fri Feb 23, 2018 3:33 pm
you can try fitting a spring to it to hold it down, just a bit fiddly getting the spring off every time you check your oil
PostPosted: Fri Feb 23, 2018 4:13 pm
Maybe try soaking it in alcohol? It may cause it to swell...
And give you an excuse to open a bottle of scotch... :lol:
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
