It is currently Wed Jul 16, 2025 1:50 am
PostPosted: Mon Feb 19, 2018 6:42 pm
If you cant find these caps you can use a chrome tow ball cover .not hard to modify them by adding a plate. I am still looking for 1 ROH cap red at the top if I cant find one I will use the tow ball cover and turn up some inserts for the wheel to you have an exact fit.
PostPosted: Mon Feb 19, 2018 8:15 pm
Just to add to this I have in the past used some stainless steel camping/picnic cups. I found on the next set of contessa wheels that the centres were a different size. Managed to use some stainless salt shakers from my local Woolworths.
PostPosted: Wed Feb 21, 2018 12:08 am
I bought a set of Weller wheel caps that fit in from behind the wheel from Minispares. Seem to fit quite well.
PostPosted: Wed Feb 21, 2018 5:21 am
I used paint spray can lids that fitted from behind, haven't given any trouble in the 12 or so years of use. Painted them the wheel colour. From memory one had to be shaved down slightly. Had some stickers made for the faces. Job done! k
1982 Honda CB1100RC (ours)
PostPosted: Wed Feb 21, 2018 3:36 pm
reckon I have some of these if someone needs them
1962 Mini Speed sports sedan
PostPosted: Wed Feb 21, 2018 6:35 pm
PM sent.
