It is currently Thu Jul 17, 2025 8:51 am
 Post subject: Metal clamping method
PostPosted: Mon Jan 29, 2018 9:10 am
Has anybody come across this method of joining sheet metal prior to welding in inaccessible places where you can't easily clamp (hopefully pic is attached)?
Apart from seeing it on a mini restoration site I have also seen it used on the tv show Fantomworks.
I am not sure how the studs are inserted, maybe with a special tool.
Greg
PostPosted: Mon Jan 29, 2018 9:46 am
They are called celco pins/clamps. There are lots of how-to and videos on the net
PostPosted: Mon Jan 29, 2018 10:09 am
Thanks. I found them under Cleco pins.
PostPosted: Mon Jan 29, 2018 2:19 pm
Widely used in the aircraft industry....
PostPosted: Mon Jan 29, 2018 7:21 pm
You can also use self tapping screws to hold panels together, seems dodgy but gives you the same finish and is way cheaper.
