It is currently Thu Jul 17, 2025 7:23 am
 Post subject: Demist vents
PostPosted: Wed Jan 10, 2018 11:02 am
Hi All,
I'm looking at installing a heater in the next few weeks, just wondering which demisting vents are suitable for the basic 850 dash and will hide behind the trim? Originality is not an issue as long as it's hidden.
I've seen minikingdom has these plastic ones listed, will these work or do they only suit the padded dash?
https://minikingdomonline.com.au/produc ... -rh-2hand/
https://minikingdomonline.com.au/produc ... -lh-2hand/
 Post subject: Re: Demist vents
PostPosted: Wed Jan 10, 2018 11:40 am
timmy201 wrote:
Hi All,
Do you have the inbuilt duct on the rhs?
PostPosted: Wed Jan 10, 2018 1:02 pm
I don't know anything about Clubmans but for an 850 wouldn't you need the earlier steel ones? I think they're quite a bit wider to fit the vent flutes cut in the top dash rail. (I don't know anything about 850's either! I assume they have the vents?)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jan 10, 2018 5:26 pm
Plastic clubby ones fit, they are much the same shape as the steel Cooper ones.
PostPosted: Wed Jan 10, 2018 5:58 pm
There is no inbuilt duct on the RHS
Thanks Kev. I'm guessing I'll need 4 x clips like this too?
https://minikingdomonline.com.au/produc ... ning-clip/
PostPosted: Wed Jan 10, 2018 7:00 pm
Can't remember after 30 years since I did mine.
PostPosted: Wed Jan 10, 2018 7:50 pm
The odd shaped rectangularish steel thing on the RHS? It's there on my '67 Deluxe, that's why I haven't got around to hooking up the heater..
Ooooh! Do I have Cooper S heater ducts? Value of the car just went up! Actually they are Mini K ones, maybe they're the same?
67 Deluxe
Dry suspension
PostPosted: Wed Jan 10, 2018 7:52 pm
No that’s for the fresh air heater which was standard on the Matic and optional on the deluxe & K.
PostPosted: Wed Jan 10, 2018 8:09 pm
You can put Cooper shrouds on top but no need really.
Looks more original without.
Users browsing this forum: Bing [Bot] and 90 guests
