It is currently Thu Jul 17, 2025 10:06 pm
PostPosted: Mon Jan 01, 2018 11:30 am
https://foxinjection.com/products/herit ... 9403888653
Has anybody tried something like this? Or know of anyone who has?
I'm considering it somewhere down the track, but know nothing a out it.
Cheers.
PostPosted: Mon Jan 01, 2018 12:06 pm
Fuel injection on 5 port mini engines is pretty tricky to get right due to the siamese ports, and for a carburettor car you need to add a new fuel system with high fuel pressure, return lines, all the sensors to get the ECU to work and you'd add in a new ignition system at the same time.
There is one here that had a similar weber style injection with a downdraft setup. You might need to register to view the posts.
http://mk1-forum.net/viewtopic.php?f=6&t=7090&start=130
He also does some videos on youtube
https://www.youtube.com/watch?v=WYiNOAEn96Q
PostPosted: Mon Jan 01, 2018 2:05 pm
That's basically what I thought was involved.
I'm running a morris 1500cc motor with custom intake manifold, already running twin 45mm dcoe webers. I also have a facet type electric fuel pump setup, and I have recently completely overhauled my ignition setup with new electronic distributor, new high power coil, new leads and plugs too... I was looking at it thinking some of the fabrication work is already done, but it still sounds like a fair bit of work and knowing what you're doing to get it done right.
PostPosted: Mon Jan 01, 2018 2:25 pm
You’ll need a fuel pump rated for fuel injection as you need much higher pressure than for a carb system. You normally have a fuel pressure regulator and a return fuel line back to the tank.
For the ignition system I’d ditch the distributor all together and use a modern coil pack and a trigger wheel for crank position sensing
