It is currently Sat Jul 19, 2025 7:48 am
 Post subject: tacho erratic
PostPosted: Fri Aug 18, 2017 5:42 pm
Have installed a new tachometer SAAS type electronic and the revs are anything from bouncing to double
Yes I have the thing wired correctly and switched to 4 cyl
Could the cheap electronic ignition be causing the problem or maybe the coil or leads ?
The car runs fine.
Any input would be appreciated
Did i tell you that all my minis are 850's ?
 Post subject: Re: tacho erratic
PostPosted: Sat Aug 19, 2017 8:26 am
yes...cheap electronic ignition...maybe.
If its easy, try going back to points to prove it or swap out the dissy for another :?: :D
PS could also be interference from copper type ignition leads...
