It is currently Sat Jul 19, 2025 4:36 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Re-chroming
PostPosted: Thu Aug 03, 2017 9:30 am
Not sure if it's still the same these days, but in SA "banding" was illegal, i.e. you couldn't widen steel heels by putting a steel band in the middle of them which was then welded on each side. But one single weld was ok, so the use of spun halves was legal.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Aug 03, 2017 9:57 am
Back then I used to do them for Parramatta speed Shop. The well on an S wheel is 1/8" smaller than a 3.50B Mini outer rim (made in Oz).
After splitting the outer rim I had to roll it down in the lathe to match the S one.
Welds were done with stick electrode, a pinhole didn't matter much as all tyres then had tubes.
