It is currently Sat Jul 19, 2025 11:21 am
 Post subject: mini van fuel tank
PostPosted: Wed Jul 19, 2017 7:19 pm
Hi does a mini van have a special pipe from the tank to the electric fuel pump. My buddys van has just been put back together after mini years and arrived as a kit set. Pump works if we use a jerry can. New to vans ta Kiwinwgtn
Edit does it also have an internal filter pick up of some sort inside the tank
 Post subject: Re: mini van fuel tank
PostPosted: Wed Jul 19, 2017 9:56 pm
There would be a strainer on pickup pipe probably. May be blocked?
Take gauge sender out for a look.
