It is currently Sat Jul 19, 2025 11:39 am
 Post subject: Tapping subframe bolts
PostPosted: Fri Jul 14, 2017 1:18 pm
One of my tower bolts is munted and will have to go a size up.
Would you just tap to 3/8 and bore out the body hole a tad ?
Would you do just do the one or make all of them 3/8?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Jul 14, 2017 1:34 pm
I'd put a recoil/helicoil in it.
http://www.millerstooling.com.au/cutting-tools-recoil-screw-thread-inserts.asp
Don't listen to what I am saying... just understand what I mean.
PostPosted: Fri Jul 14, 2017 4:16 pm
Simon,
If you want to go the drill & tap at 3/8, i have a long tap & drill bit to suit the job if the subframe is still on the car.
1965 MKI
1972 MGB GT
http://rossjohnsonphotography.zenfolio.com/
https://www.facebook.com/RossJohnsonPhotography
PostPosted: Fri Jul 14, 2017 5:56 pm
Weren't there subframe studs that were 3/8" to 5/16" stepped?
PostPosted: Fri Jul 14, 2017 10:49 pm
Yes!
PostPosted: Fri Jul 14, 2017 11:01 pm
Thanks rossco that's a very kind offer. My is frame is however sitting on the bench already. ;)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Jul 15, 2017 7:54 am
Be careful if drilling out the hole in the cross member, it is just a thin tube. To stop the body collapsing when bolt is tightened.
PostPosted: Sun Jul 16, 2017 3:01 pm
Yes that is problematic! Thanks doc . That's why I'm hesitant to go up to 3/8... not sure if any other options though..
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Jul 16, 2017 5:06 pm
Just put a new thread in it.
PostPosted: Sun Jul 16, 2017 7:18 pm
Helicoil/thread repair insert you mean?
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sun Jul 16, 2017 8:49 pm
Yep.
Sent from my Nexus 5X using Tapatalk
PostPosted: Mon Jul 17, 2017 7:27 am
Tim I wrote:
Yep.
Thanks Tim
Would the size be 5/16 24 unf?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Jul 17, 2017 9:44 am
simonw wrote:
Thanks Tim
Yes.
Drill it out to the size in the instructions (in this case 21/64") then tap it with the supplied special tap before screwing in the thread insert with the supplied tool.
There are other brands, but these Pro Thread ones are available in a lot of tool shops here in Adelaide. Cost about $30-35 for the kit that includes 4-5 inserts, and you can buy more inserts as well as different lengths.Image
PostPosted: Mon Jul 17, 2017 4:09 pm
Great advice . Thank you!
Simonw
Brisbane QLD
- 1969 Mini K
