It is currently Sat Jul 19, 2025 11:49 pm
 Post subject: Master cylinder rebuild
PostPosted: Mon May 22, 2017 10:10 pm
Hey all, just chasing opinions on a bit of pitting in a master cylinder. I gave it a quick hone and the only bit of corrosion that didn't come out is as pictured. I can't feel it when I rub my finger on it, but just don't know if I should proceed with a rebuild or should expect it would be doomed for failure?
PostPosted: Mon May 22, 2017 10:41 pm
The worst that can happen is that you may find it leaks a bit once you get it back together... it won't suddenly fail.
If you can't face doing it twice then get a new one.
Otherwise give it a go... if you can't feel any roughness then I would be optimistic.
Cheers, Ian
PostPosted: Mon May 22, 2017 10:49 pm
The first seal starts a long way down the bore. Just measure the depth from the circlip groove to the seal.
PostPosted: Tue May 23, 2017 11:13 am
You could also get iy resleeved in stainless steel :!:
