It is currently Mon Jul 21, 2025 10:12 pm
 Post subject: Tacho problem
PostPosted: Wed Mar 15, 2017 11:51 am
I have just replaced the wooden dash with the origional binicle on my mark 2. I also placed the tacho in front of the steering wheel. However I am getting electrical interference, ie it pulses with the electrical pump and drops to zero when the lights are on. I sourced the power for the tacho from the terminals behind the speedo. Could that block be faulty. I also tryed a lead direct from the coil but still the same? any ideas please.
 Post subject: Re: Tacho problem
PostPosted: Wed Mar 15, 2017 1:26 pm
Have you connected the 12v wire (+ve) to the 10v terminal on the thing you call the "block" (it's the voltage regulator)?
The 10v terminal is labelled "I" whereas the 12v terminal is "B".
PostPosted: Wed Mar 15, 2017 4:05 pm
Thank you, I will check that
PostPosted: Thu Mar 16, 2017 8:48 am
and check your earth for the tacho
PostPosted: Fri Mar 17, 2017 6:42 am
It was a wire earthing within the tacho.
Thank you.
Ian
