It is currently Wed Jul 23, 2025 9:00 pm
 Post subject: Diff Assembly
PostPosted: Sat Jan 14, 2017 12:52 pm
Has anyone ever bothered to check the run out on the two bearing spigots after assembling a diff centre
That is after bolting the large driven gear to the spider gear housing
Bit of a trick to do but my one isn't behaving very well as in run-out
Or is this just BMC Quality
1970 MK2 Cooper S
 Post subject: Re: Diff Assembly
PostPosted: Sat Jan 14, 2017 7:33 pm
How much runout do you have?
PostPosted: Sun Jan 15, 2017 6:29 am
it varies as to where i put the crown wheel
0.010" in one position
i moved it 2 holes and its down to 0.003"
I am using a new cross pin centre so i can dial in the hub next to the crown wheel
1970 MK2 Cooper S
PostPosted: Sun Jan 15, 2017 9:17 pm
You have got to be happy with that??
PostPosted: Mon Jan 16, 2017 5:19 am
No not really
1/2 thou might be ok
1970 MK2 Cooper S
PostPosted: Mon Jan 16, 2017 6:11 am
It's a helical gear, so lateral runout is not as critical as a spiral bevel or hypoid gear set.
And it's a 2 piece hemisphere, normal diffs are 1 piece. So tolerances stack up. Maybe worse with an aftermarket gear.
I think you are being a bit critical considering its design.... ;)
PostPosted: Mon Jan 16, 2017 10:25 am
Not really
I am looking at it from an engineering view point
Close enough isn't good enough
If there was a little bit of clearance I could dial the 2 halves in and get it perfect
Sent from my HTC_PN071 using Tapatalk
1970 MK2 Cooper S
PostPosted: Mon Jan 16, 2017 4:53 pm
Problem fixed
Took about 5 mins to do and achieved zero run out
Engineering as it should be
1970 MK2 Cooper S
PostPosted: Mon Jan 16, 2017 8:21 pm
GundyGuy wrote:
Problem fixed
What did you do to get it to Zero ?
PostPosted: Tue Jan 17, 2017 5:10 pm
I took a few thou off the stem of the bolts and thats all it took to get it to behave
1970 MK2 Cooper S
PostPosted: Tue Jan 17, 2017 7:50 pm
So the unthreaded part of the bolt just under the head was pulling it out of position !
PostPosted: Wed Jan 18, 2017 5:16 am
Thats correct
the bolts were all different sizes
so i made them all the same
only about 3 thou between them
but enough to cause a problem
1970 MK2 Cooper S
Users browsing this forum: Steam, watsupskip and 106 guests
