It is currently Wed Jul 23, 2025 9:00 pm
 Post subject: Rad Top Hose Size
PostPosted: Wed Jan 11, 2017 9:28 pm
So the rad has a 25mm spout and the 'stat is the same size.
The only size hose that is the correct shape is 28mm ID.
Is there a source for either silicon or rubber hose that would fill the gap?
So needs to be 25mm ID / 28 mm OD and about 1.5mm wall thickness.
I could then fit the top hose over it.
I have searched muchly with no luck.
 Post subject: Re: Rad Top Hose Size
PostPosted: Thu Jan 12, 2017 7:27 pm
So why won't a standard radiator top hose fit like this
http://minikingdomonline.com.au/product ... ose-top-4/
PostPosted: Thu Jan 12, 2017 7:52 pm
Thanks for the pic mate. Hard to be certain but it looks too flat.
Because of my set up there is a step of about 20mm between the MPi stat housing and the rad tube.
PostPosted: Fri Jan 13, 2017 12:17 am
http://minispares.com/product/Classic/Cooling_heating/GRH1212.aspx
This hose looks to be offset to work with the sandwich plate.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Fri Jan 13, 2017 7:35 pm
That looks the go! Thanks Matt I. Will get one ordered
Users browsing this forum: Steam, watsupskip and 106 guests
