It is currently Thu Jul 24, 2025 3:32 am
PostPosted: Tue Dec 27, 2016 8:52 am
Hi all
Looking to put my side badges on the clubby. Does any one have exact positioning info or is it a case of best guess?
Most pics I've found show this spot:
Eiles
PostPosted: Tue Dec 27, 2016 12:02 pm
Eiles, -I just checked an old photo of my 1971 Clubman when it was new, & the Leyland badge is roughly in this spot. It looks like the bottom edge of the badge is the same distance above the door hinge casting as the rear edge of the badge is from the A pillar gap, & the front of the badge appears to be level with the front of the hinge casting.
The photo above shows the badge a little further rearward than mine was.
PostPosted: Tue Dec 27, 2016 12:43 pm
Thanks for that. :)
Will make up a little template and use that.
PostPosted: Tue Dec 27, 2016 6:02 pm
There was a thread a while ago that did give measurements, cant recall what its called though.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Dec 27, 2016 6:05 pm
Found it!
viewtopic.php?f=2&t=88446&hilit=badge+leyland
5/72 Clubman Gt
PostPosted: Tue Dec 27, 2016 9:51 pm
Thanks Scoop!
I used 3m double sided tape as I didn't want to drill any holes.
This is how it turned out:
Eiles
