It is currently Fri Jul 25, 2025 9:33 am
 Post subject: brake line location
PostPosted: Thu Dec 15, 2016 5:03 pm
The brake lines in the rear sub frame are bent in a way that they match up fitting the hole as per the picture, the bend looks to me like a factory bent piece but I could be wrong. My understanding is that the line should pass through the other hole above but then the line will not match the location of the bias valve, so which is the correct location the brake line passes through? Is it the other hole above? Which then means the bend in the line is wrong/not factory... this would be my guess.
Jenk.
 Post subject: Re: brake line location
PostPosted: Thu Dec 15, 2016 5:22 pm
Brake line routing is different on hydro and dry rear arms. Hydro cars have the brake line below the arm and use the lower hole (as you have), I think because of that bump stop. Dry cars use hole in the angled plate, and the brake line runs along the top of the trailing arm.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
