It is currently Fri Jul 25, 2025 9:33 am
PostPosted: Wed Dec 14, 2016 7:37 am
Hi, can any of you people who have a rod change gearbox measure the location of the floor hole for the rod change bracket, say with respect to the inner bolt hole for the passenger seat?
I am just trying to make sure I've got everything in the right place before it goes off to the panel beaters, especially the tab for the other bolt hole which I have had to fabricate.....
I have a photo which is helpful but I am having to guess distances.
Thanks!
Steve
PostPosted: Thu Dec 15, 2016 11:03 am
Hope this helps,
A- subframe upper mount hole centreline to left shift Box mount center. 375mm
B- subframe upper mount hole centreline to right shift Box mount centre. 378mm
C- right inner sill to right shift Box mount. 625mm
D- left to right shift Box mount holes. 133mm
E- left inner sill to left shift Box mount. 508mm
F- front of crossbeam to right shift Box mount. 89mm
G- front of crossbeam to left shift Box mount. 92mm
Measurements from a 76 Leyland.
Best I can manage,
Silas
PostPosted: Thu Dec 15, 2016 1:06 pm
Thanks for that Silas.....! :lol:
Looks like I was only 10mm out..
Can sleep at night now.....
