It is currently Fri Jul 25, 2025 9:36 am
 Post subject: Gear Set ID
PostPosted: Sun Dec 11, 2016 7:48 pm
Found a couple of 3 synchro gear boxs that look to have reasonable gearsets in them.
Laygears are 22G231 and AD016.
Are these gearsets anything special or just 850 and deluxe?
 Post subject: Re: Gear Set ID
PostPosted: Mon Dec 12, 2016 12:18 pm
The Mini King
22G231 is B form Laygear
ADO16 is A form Laygear
If the diff hemisphere housing in the gearbox with ADO16
is a reddish brown colour.
and it is in good condition, you have probably the best
ever made hemisphere housing " In my opinion "
and can be used in all Mini Gear Box's
PostPosted: Mon Dec 12, 2016 12:54 pm
Is the "diff hemisphere housing" the one that holds the spider gears?
Sent from my GT-I8730 using Tapatalk
PostPosted: Mon Dec 12, 2016 4:17 pm
The Mini King
Yes, Spider Gears are also referred to as planetary Gears.
