It is currently Fri Jul 25, 2025 9:35 am
PostPosted: Sun Dec 11, 2016 11:02 am
Hi everyone, I have another 1100 motor out the back I am wanting to try and see if it will start. It is sitting in its subframe and everything is on it, all ancillaries. Can I start it up somehow without wiring harness?
Thanks,
Steve
PostPosted: Sun Dec 11, 2016 12:23 pm
Yep you can run a thick gauge cable from the battery positive to the starter motor. Thick Earth cable from battery negative to the engine block. Then a smaller gauge wire from the positive via a momentary switch (from supercheap, repco or Jaycar etc) to the starter solenoid to kick it over.
I also run a big battery isolation switch so you can kill the engine when you need to.
Voila, good to go.
Sent from my Nexus 6P using Tapatalk
PostPosted: Sun Dec 11, 2016 1:13 pm
do I need something going to the coil?
PostPosted: Sun Dec 11, 2016 7:40 pm
Yes. A positive wire.
You can pull it off to stop the engine as you will have no ignition key !
