It is currently Fri Jul 25, 2025 9:36 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Dec 08, 2016 1:01 pm
If you want to use with vacuum advance then you may want to look into the Aldon Amethyst as it has provision for both mechanical and vacuum advance. There are a number of models but the one you would want is the vacuum model. It will work with both traditional points and various electronic points units.
I've got one ordered for my midget :P
Rod
PostPosted: Sat Dec 10, 2016 7:58 am
Ahh! When you guys said "disk" I thought floppy! :D
CD drive, that I can find!
Thanks all
My Mini --> 1966 Riley Elf (currently in pieces!)
PostPosted: Sat Dec 10, 2016 8:30 am
Thanks all
5 1/4", 8" or 3.5" Maybe have them all covered :roll: :oops:
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Sat Dec 10, 2016 11:17 am
Thanks all
PostPosted: Sat Dec 10, 2016 12:11 pm
Phil,
My HSC work experience in 1979 was at ICL computers changing those bloody reels over. State of the art at the time haha! My 64 Gb micro memory card holds more data than a room of those things I expect...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Dec 10, 2016 12:43 pm
My first job in 1965 was a computer operator on an IBM 1440 like this. It didn't come with the female accessory shown in this picture but the separate punched card room was staffed by woman only environment at the time.
PostPosted: Sat Dec 10, 2016 1:14 pm
Subject has gone completely off track!
"Let us remove your "SHORTS"
