phillb wrote:
2lateagain wrote:
John, I think you are on the money, the offside flitch panel has been replaced/repaired badly and it looks like both sides have been worked on back to the bulkhead, some very dodgy welding under the sealant and holding the guards in place, some sections not in line with other bits, so it looks like the whole front will be coming off in the future when the rotisserie is vacant. Thanks for the input, going to require a bit more work than previously thought. Think that the panels will be ok with a bit of convincing.
Graham
I remember now the small opening at one end of the front panel is a sign of a replacement panel. The originals were solid here.
You'll need to also to replace the vertical brace with a angled one if you want an oil cooler refitted, and fold back part of the lower edge of the grille opening.
The replacement front panel I used some years ago is here.
It is different from the one in the photos in the original post. I had to close over the opening too, and take of the brackets for the number plate mount, replacing them with the ones from a donor Deluxe.
The reason for replacing the front panel should be obvious, but the reason why the distortion was created during a repair is not so.
