It is currently Sat Jul 26, 2025 11:47 am
 Post subject: Re: Generator upgrade
PostPosted: Thu Nov 03, 2016 12:48 pm
Actually after refreshing my memory it is quite interesting how those regulators work.
One relay cuts the generator out when the revs drop low to prevent the battery driving the generator and turning it into a starter motor.
The other regulates the voltage by vibrating essentially at around the correct voltage, too high it cuts out, too low it cuts in which happens very rapidly. You should be able to see these relays operating if you remove the cover.
PostPosted: Thu Nov 03, 2016 7:23 pm
yep bulb is continually on, the battery was most deffo losing charge.
and so, I have replaced with new, the fuse box, the regulator and put the last generator back on, and . . . . .
the bloody ignition light is still on, so, back to the original question, I have a new generator and so how the **** do I get that pulley wheel off so I can put a brand new generator on to sort this once and for all?!?!
the new generator has a slight lip on the spindle so as to lock with a screw driver, yet the 3 others I have don't appear to have anything similar.
but hey, the horn works now ha ha ha
taaaaaaaaa for the advice
1968 Mini-Matic
PostPosted: Thu Nov 03, 2016 7:37 pm
Are you having trouble removing the nut or the pulley?
PostPosted: Thu Nov 03, 2016 8:11 pm
I used an old fan belt wrapped round the pulley and clamped tight in a vice, then used a rattle gun to buz the nut off
http://i661.photobucket.com/albums/uu33 ... xsdck9.jpg
PostPosted: Thu Nov 03, 2016 9:46 pm
If you're keen pull the generator apart and hold the armature in a vice (soft jaws?) then undo the nut the usual way.. Or else use your imagination or any of the above suggested methods.......... :wink:
PostPosted: Fri Nov 04, 2016 5:09 am
i had the battery not being charged, i thought it was the generator. but turned out to be the voltage regulator.
it was band new from the UK. I took it to an auto elec and he said it was faulty and would cost to investigate why. (cost me $20 for him to quote
i put in an old lucas one from a land rover, now working fine.
PostPosted: Fri Nov 04, 2016 6:04 am
Take it to an Auto Lecco and ask them if they can change it over for you ,shouldn't cost much .
PostPosted: Fri Nov 04, 2016 7:21 pm
Buy a rattle gun...
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Nov 08, 2016 4:30 pm
I ended up doing just that goodie, got him to test 2 old generators for me too, and they were both not working - so 3 out of 3 buggered!
Got the new pully wheel on, just put it all back, with new regulator and fuse box and all is as it should be, no light, horn works a treat too.
thanks all for the advice
now, what's next that needs fixing . . .
1968 Mini-Matic
PostPosted: Thu Nov 10, 2016 7:07 am
Glad you got it sorted .
Users browsing this forum: justminis, stewartp and 96 guests
