It is currently Sun Jul 27, 2025 8:33 am
PostPosted: Tue Oct 04, 2016 12:57 pm
Is this the original design ?
I have a hole in the pin that looks to accept a split pin type arrangement ....
However the manual indicates it's a clip :/
Anybody with a picture of the original ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 04, 2016 1:01 pm
don't have a picture, but the original clip is more like a single piece of spring wire bent into the circlip shape, rather than the type shown on minispares
if yours has a hole drilled for a split pin, then that's been done by someone who lost the original clip
PostPosted: Tue Oct 04, 2016 2:13 pm
The one shown as a Mini Spares item is in fact an E-Clip. The double wound wire clip is a special wire clip which has fallen into dis-use.
PostPosted: Tue Oct 04, 2016 5:22 pm
All of the above is correct. I just lost one while trying to press it into its groove.
I have a small collection of E-clips that will work if you would like some. But will lose you concourse points.
PostPosted: Tue Oct 04, 2016 7:05 pm
ahhh, that's right - mental block... sometimes also known as a jesus clip, as in "jeezus, where the f*ck did that go"
PostPosted: Tue Oct 04, 2016 7:44 pm
Thanks gents ! I ordered and have 2 on hand , but they just don't fit well and I couldn't remember what the originals looked like as its been a year since I pulled it apart ! More likely I lost them in the zinc plating process....
Any body with a picture of what's supposed to be there or is it not worth being that finicky ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Oct 05, 2016 5:59 am
simonw wrote:
<snip>..
http://www.circlips.com.au/content.php? ... lips#plain
(it's the one labelled "special wire rings")
PostPosted: Wed Oct 05, 2016 6:18 am
That's a great resource DavidE thank you
I'll see if I can scrounge up some these
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Oct 05, 2016 5:43 pm
Hello Simonw,
I would like a few of these circlips too! Lost one fitting the helper spring and they are not common - like MKO has none.
Can you let the site know if you have any success?
PostPosted: Wed Oct 05, 2016 10:16 pm
Will do Bill
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 17, 2016 12:01 pm
So I found one of these. Looks very similar to the diagram. However it's a valve collet retainer clip of a cylinder head. If this is the same clip that can be used on a hydro spring retainer, then fantastic we found a source. I have 20 or so !
However there is a little problem. Seeing as my helper spring pin doesn't have a groove in it any more I'm at unable to confirm that this clip is of use. I did put it on as a trial and it seems to be of sufficient circumference.
Maybe someone can confirm whether this is going down the right track or not
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 17, 2016 8:03 pm
Hello Simonw,
That isn't the right clip. In DavidE's photo, it's the A1200 clip that looks like a "c" inside a "c".
Good try though!
Bill
PostPosted: Tue Oct 18, 2016 9:09 am
Haha I knew it was toooo easy ! Back to the drawing board[FACE WITH TEARS OF JOY]
Simonw
Brisbane QLD
- 1969 Mini K
