It is currently Sun Jul 27, 2025 7:45 am
PostPosted: Sat Sep 03, 2016 12:23 pm
Just fitting the gearbox to the motor (finally) and wanted to make sure I had the right gasket.
As you can see from the photo, the gasket covers the O ring. Is this correct or should the hole in the gasket be bigger to allow for the o ring to meet directly with the block?
PostPosted: Sat Sep 03, 2016 12:27 pm
it's fine...
PostPosted: Sat Sep 03, 2016 3:40 pm
Thanks Simon
PostPosted: Sat Sep 03, 2016 11:12 pm
I'd trim it back?? better to be safe than sorry :?:
Lillee - 1969 Morris Mini K
PostPosted: Sun Sep 04, 2016 6:52 am
I'm with Lillee
The paper gasket is to stop oil leaking between the block and gearbox. The O Ring is to stop oil leaking in the same place but at 80 psi.
I'd have a clean smooth surfaces for the O Ring to seal on.
Just my opinion :D
PostPosted: Sun Sep 04, 2016 8:28 am
Gasket has always covered the o-ring by design. This one is badly cut or has shrunk. Trim it or fit a better gasket.
PostPosted: Sat Oct 08, 2016 1:27 pm
The gasket on the other side isn't cut to the same shape, is this normal or should I ditch the pair and buy a new set?
PostPosted: Sat Oct 08, 2016 1:30 pm
they can't/shouldn't be the same shape - the gaskets you have are correct
PostPosted: Sat Oct 08, 2016 7:22 pm
Iv'e done hundreds of these. Never trimmed the gasket once. Never had a problem.
PostPosted: Sat Oct 08, 2016 8:03 pm
Ditto.
But don't forget to fit the O-ring, guaranteed to suck air without it.
PostPosted: Sun Oct 09, 2016 7:58 pm
There are 2 types of front edge gasket for the engine /gearbox face.(opposite side to the O ring)
One for 1275 motors and the other, shown in the pic, is for a small block - 1098,998, 850 etc.
If you use the small block gasket on a 1275 the rods hit the paper gasket and break off bits which can then get into the oil system.
The 1275 gasket follows the contours of the gearbox edges and doesn't over lap into the gearbox inner area.
RonR
68 build Mk1 Cooper S
PostPosted: Sun Oct 09, 2016 8:51 pm
Now that I have just done this tonight, you don't need to cut the gasket. If you invert he motor and place the gearbox onto the block, the O ring seals onto the gasket with block along with gasket sealant that you use.
PostPosted: Sun Oct 09, 2016 10:23 pm
Thank you
