It is currently Sun Jul 27, 2025 4:54 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Speedo correction
PostPosted: Sun Oct 02, 2016 9:00 pm
I see that Matt, but I'm installing the motor/gearbox this week so can't wait till something turns up.
9yatah - Just got off the phone to a bloke, he has quite a few speedos of various types, and several gearboxes. Don't expect any luck with the gears, but the speedos look promising. I'll keep you in mind if there are a few 1280 type speedos.
PostPosted: Sun Oct 02, 2016 11:12 pm
You could probably change the speedo drive gears with the engine in the car with the radiator out if need be.
The 7-18t combination that you need for your existing speedo is a bit rare even in the UK, though Guessworks seem to source used ones fairly often. There are two possible 7-18t sets, but I note they don't have the 7t listed for either at the moment.
When we got ours, postage was fast and reasonably priced.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Mon Oct 03, 2016 8:15 am
I put a Moke 140kmh one in mine. Is marked 800 turns/km. With a 3.44 diff and std speedo drive gears it is pretty spot on. And no need to do mph/kmh mental arithmetic. :)
