It is currently Sun Jul 27, 2025 11:34 pm
PostPosted: Sun Sep 04, 2016 7:15 pm
Hey guys,
I have a early (63-64) Morris 850, Im in the process of restoring the car and Im rebuilding the radius arms. I have the radius arm rebuild kit (bearing, brass bush, plastic sleeve) and I've removed the bearing and bush, BUT there is no plastic sleeve, I've tried to use a flat head screw driver on the edges and its not breaking/cracking like plastic should, its metal!..... any ideas? thanks in advance.
PostPosted: Sun Sep 04, 2016 7:29 pm
Original sleeve is steel. Keep them, the plastic sleeve in the kits is rubbish.
They can crack, then the whole arm casting fills with grease.
PostPosted: Sun Sep 04, 2016 7:33 pm
thanks for the quick reply. I've damaged the edge of the sleeve on both sides (with the flat head screwdriver) as i was trying to remove it. would it damage the replacement shaft? what should i do?
PostPosted: Sun Sep 04, 2016 8:03 pm
Just panel beat it back as best as possible, won't worry the shaft.
PostPosted: Sun Sep 04, 2016 9:12 pm
Shaft is hardened.
PostPosted: Sun Sep 04, 2016 10:12 pm
sweet... was a tad worried for a moment. I'll keep the original sleeves (after i tidy them up). Thanks guys!
