It is currently Sun Jul 27, 2025 11:28 pm
 Post subject: Camshaft nut tension
PostPosted: Sat Sep 03, 2016 7:10 pm
Do we have a list of bolt tensions somewhere?
What is the tension for the nut that holds the sprocket onto the camshaft?
 Post subject: Re: Camshaft nut tension
PostPosted: Sat Sep 03, 2016 8:33 pm
http://www.minimania.com/Mini_Torque_Wr ... ttings_597
PostPosted: Sat Sep 03, 2016 8:49 pm
The specifications section of the workshop manual with torque settings is here - http://www.ausmini.com/manuals/Mini%20W ... 20Data.pdf
The full manual is here - viewtopic.php?f=25&t=84427
PostPosted: Sat Sep 03, 2016 10:12 pm
Guys,
Thanks for the info.
The manual in the link appears to be similar to the ones I have in that it does not have the tension for the camshaft nut.
PostPosted: Sun Sep 04, 2016 7:25 am
As posted above. First spec in engine list.
1963 Morris 850
PostPosted: Sun Sep 04, 2016 7:41 am
I do them to 70 ft/lb with Loctite 262 and no locktab. Never had one come loose.
PostPosted: Sun Sep 04, 2016 9:57 am
I might of overlooked it, but is there a Clubman workshop manual here winabbey?
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
