It is currently Sun Jul 27, 2025 10:19 pm
 Post subject: Sunvisor screw location
PostPosted: Sun Aug 28, 2016 9:59 am
Does anyone have a photo of the position of the sunvisor screws for a 1967 Cooper S?
I had a new roof lining fitted some time back and now I can't locate the screw holes and not sure what type of screws they use.
PostPosted: Sun Aug 28, 2016 7:50 pm
Are theses the ones ?
Right hand side in first photo, left hand side in second photo.
PostPosted: Mon Aug 29, 2016 4:27 pm
Brilliant thanks for that.
PostPosted: Mon Aug 29, 2016 7:15 pm
Hi Minicooper4me,
What model Mini are the photos from?
First time I have seen that arrangement with the speed nuts.
Ones I have seen have small holes for self tappers on either side of each visor.
(With 850's having the two holes close together.
PostPosted: Mon Aug 29, 2016 8:54 pm
Are your visors like these in a MK II S? If so does the mounting position and method help? Or are they one of the types in the parts book?
PostPosted: Mon Aug 29, 2016 9:05 pm
Mine are number 27 in Doug's part book. Mine are standard 1966 deluxe and only saw the speed nuts which hold the self tappers when I stripped the body bare for the rebuild. When I fitted the new hood lining, I took photos first, then cut out the hood lining hole when fitting the new lining.
PostPosted: Tue Aug 30, 2016 6:16 pm
Spot on, the ones in the photos are the same as mine, thanks mate.
Users browsing this forum: TartanRed and 99 guests
