It is currently Mon Jul 28, 2025 12:07 am
 Post subject: Hs2 throttle return
PostPosted: Wed Aug 17, 2016 1:01 pm
Hi all,
My mate is retoring a 62 850.
He isn't sure how the throttle return spring works on it.
On my hs4 there is a bracket between the carb and the manifold that the spring connects to.
Are hs2's the same? Or do the return springs connect somewhere else?
1975 Hairy Lime/White Clubby
 Post subject: Re: Hs2 throttle return
PostPosted: Wed Aug 17, 2016 2:08 pm
From memory, mine had a little bracket on the exhaust clamp?
Part #30 i the diagram - 12A5
http://www.minispares.com/catalogues/cl ... spx?1~6~58
PostPosted: Wed Aug 17, 2016 2:09 pm
Correct.
PostPosted: Wed Aug 17, 2016 2:22 pm
It's just a bent piece with a hole in each end. There is a diagram here
http://mk1-forum.net/viewtopic.php?f=8& ... hilit=12a5
