It is currently Sun Jul 27, 2025 11:50 pm
PostPosted: Fri Aug 20, 2010 4:51 pm
Supercharged
hard bit will be fixing the tail lights, but i know you can get panels from the UK to retrofit mk1 lights to rovers etc.
PostPosted: Fri Aug 20, 2010 5:29 pm
I think the gaurds will be harder as they have been chopped for the big wheels. need to replace the fenders and a panels.
PostPosted: Sat Aug 21, 2010 8:28 pm
Won'tbe going for a drive, checked all the fluids and the engine started straight away but when driving it back into the shed i used the brakes and the front left locked on hard and would release, good news laid my first burnout....lol
Had to jack it up and take the wheel off, couldnt shift the pads back until i cracked the nipple... would this mean that the fliud is unable to return the to master? or is this common for a car that hasn't been driven for years?
Any way... check out what was under the seat covers.
PostPosted: Sat Aug 21, 2010 8:40 pm
I'd be saying something is stuck in the Hydrolics and i would guess it would be the master. Was the Peddle floppy. Its not the piston in the brake as you released the pressure by undoing the nipple and the piston came back which is why I think the master.
That seat looks Perfect. Put the cover back on it :wink:
PostPosted: Sat Aug 21, 2010 9:01 pm
Can anyone confirm the seats and door cards are correct for late 67 Cooper s???? Watto??please??
PostPosted: Sun Aug 22, 2010 2:44 am
I'm 90% sure brake issue will be a hose, they break down internally and act like non return valves, best to look at the caliper pistons too, make sure no corrosion on chrome plated piston sides.
Seats look right to me, I think the door cards too, later mk1 style as opposed to single heat indented 'flash' on earlier Mk1 cards.
Should be a great car! Good luck! 8)
Sir Alec! we are not worthy!
PostPosted: Sun Aug 22, 2010 11:03 am
Yes, the seat trim and door cards are correct for a late 67, they are the later Mk1 type. You are lucky as the earlier door trims are heat welded and more difficult to replicate if needed.
PostPosted: Mon Aug 15, 2016 9:38 pm
Funny what you can find on youtube. Nice video Tim
https://www.youtube.com/watch?v=r-8rkW2nQhQ
PostPosted: Mon Aug 15, 2016 10:23 pm
great car and video
1968 Morris Mini Cooper S
PostPosted: Tue Aug 16, 2016 10:47 am
That was a popular colour to paint a Cooper S back then. It looks like Portsea Blue, a EH Holden Premier colour. My mk2 was painted that at some stage. Will be taking it back to Crystal White.
PostPosted: Tue Aug 16, 2016 5:26 pm
Is there a pic? Or has the pic been removed?
Zulu...
1967 mini Cooper S
PostPosted: Tue Aug 16, 2016 6:33 pm
He took them down yesterday. Just watch the video.
PostPosted: Tue Aug 16, 2016 10:13 pm
Got it.
Zulu...
1967 mini Cooper S
