It is currently Sun Jul 27, 2025 11:55 pm
PostPosted: Sun Aug 14, 2016 3:55 pm
Ive read a bit about it and could knock one up but my time outside of work is pretty limited for shopping, so does anyone in newcastle have a cone compressor i could borrow? Payment in beer, weekend car work or love.
Nic
Sent from my SM-G900I using Tapatalk
PostPosted: Mon Aug 15, 2016 2:16 pm
just remove the top control arm completely
you won`t need the spring-compressing tool
fit hi-lo adjuster struts back in & again , no need for compressing tool
re-new the control arm bearings & pin & seals while you`re there
check the 'seat" inside the top arm for the cone shaped seat that needs to still be cone-shaped for the new nylon cup to seat correctly
if you fit a new nylon cup into a worn arm it will distort quite quickly & you will have problems
Matt
PostPosted: Mon Aug 15, 2016 6:37 pm
How hard is it to remove the top arm? I'd like to replace all my bushes and rubbers in the front end and haven't attacked the suspension yet
1968 Morris Mini Cooper S
PostPosted: Mon Aug 15, 2016 9:02 pm
not doing hi-lows and i was thinking of putting new cones in but wasn't sure. never had the suspension out so dunno what to expect, just don't want to get half the job done.
PostPosted: Mon Aug 15, 2016 9:22 pm
This is how I did it
viewtopic.php?f=2&t=91132
