It is currently Mon Jul 28, 2025 1:31 am
 Post subject: Glass scratches
PostPosted: Sun Jul 31, 2016 6:14 pm
Hi all is there any way of getting scratches out of glass?
 Post subject: Re: Glass scratches
PostPosted: Sun Jul 31, 2016 7:19 pm
Yes, but depends how badly. You can do it with a random orbital polisher and glass polishing compound. I've tried this myself with mixed results but apparently you need a pretty powerful polisher ($$$) and mine is an entry level. It will remove and fill in very very minor scratches but any deeper than a few microns I think you need to talk to a glass specialist?
Lillee - 1969 Morris Mini K
PostPosted: Sun Jul 31, 2016 8:08 pm
try tooth paste on the polisher, takes a while but does eventually cut through the scratches
1969 Cooper S
PostPosted: Sun Jul 31, 2016 10:41 pm
Be careful with your toughened glass windows and original Mini (non S) windscreens. The outer layers are in compression, if you do much heavy polishing work it can go BANG! So a glass merchant told me.
PostPosted: Mon Aug 01, 2016 2:09 pm
I did read about someone even just using clay bar on their windscreen and BANG!
Might have been here on Ausmini.......
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Aug 01, 2016 6:02 pm
It's the rear screen and has a scratch that you can feel with your finger nail. Right it in the bloody middle
