It is currently Mon Jul 28, 2025 9:45 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jun 15, 2016 9:54 am
timmy201 wrote:
Minicooper4me wrote:
Just resurrecting this post.
Have had a scrounge in the shed spare part division, have found 2 complete pot joints and 2 drive shafts. What more do I need to convert over from rubber universal joints. Do I need to change the diff output shafts and the diff covers.
Diff output shafts are different. Pot joint ones have a circlip to hold the "pot" on the output shaft
http://www.minispares.com/product/Classic/DAM3114.aspx
Diff covers are the same
Make sure that the driveshafts you have match the pot joints. The pot joint driveshafts aren't compatible with the rubber uni or Hardy Spicer couplings. There should also be a long and short driveshaft
Thanks Timmy, much appreciated.
Both the pot joints and the drive shafts are matched. Came from the same gearbox.
Can I use second hand diff output shafts. They are readily available.
PostPosted: Wed Jun 15, 2016 10:08 am
Second hand ones are fine, as long as they aren't worn where they rotate on the crownwheel & diff bushes.
PostPosted: Wed Jun 15, 2016 12:40 pm
Thanks Timmy, you're a champ.
PostPosted: Wed Jun 15, 2016 5:22 pm
lol it is now sold as a kit! How times have changed from ye olde days of scrounging for parts!
http://minikingdomonline.com.au/product ... pot-joint/
Sorry off topic a little. Back in my box
Lillee - 1969 Morris Mini K
PostPosted: Wed Jun 15, 2016 5:41 pm
That's cool Lillee. Scrounging is good, you don't what else you will find in the Aladdin's cave. At least we know that kits are available. LOL.
