It is currently Mon Jul 28, 2025 2:18 pm
PostPosted: Sun May 22, 2016 3:27 pm
Hi,
Has anybody had experience in removing the stainless trim from the window frame? I'd like to remove it prior to painting but it looks like it is there for good, in which case it can stay.
thanks
Jon
PostPosted: Sun May 22, 2016 4:18 pm
Done it quite a few times using the following method:-
- Lie the door down on its outside using something quite giving, like foam, so as not to dent the door skin
- Brace the window frame, even someone holding it is okay
- Start at either end of where the trim ends or you can start at the top 90 degree bend
- Use a piece of timber about 50mm x 25 mm and, say, 150mm long
- Place the 50mm side of the timber on the outer lip of the stainless trim. There is a distinct ridge.
- Hit the other end of the timber with a medium hammer. Hard to describe level of impact required, but it needs to be sharp and fairly hard.
- The trim will just "pop" off
- Work your way around the window
Scary but works okay. Good luck.
PostPosted: Sun May 22, 2016 4:47 pm
Also, spray the edge of the trim with a lubricant of sorts, like WD40, to help the trim slip off the window frame.
PostPosted: Sun May 22, 2016 5:43 pm
...and above all else, take it easy, and carefully.
PostPosted: Sun May 22, 2016 7:09 pm
Found it fairly easy to do whilst the door is still fitted to the car.
PostPosted: Sun May 22, 2016 7:11 pm
Getting it off is not the problem. Replacing it without damaging a new paint job, Arghhhhh!!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun May 22, 2016 8:06 pm
Yes, you really need to take care. Let the paint get well cured. Again lubrication is the trick. Thoroughly clean and smooth out the inside of the trim with fine sandpaper. Add grease to the inside of the trim and the window frame. The trim should then "press" into position with a bit of effort.
PostPosted: Sun May 22, 2016 8:25 pm
Thanks all. I'll have a go but at the end of the day if it's too difficult might give it a miss...
PostPosted: Mon May 23, 2016 6:11 pm
I'm an amateur and did it as above, didn't have any problem. Light tap with a block of wood and hammer with door lying down on its side. Tapped stainless on the very edge and it came off without any damage to trim or door. The narrow edge of the smaller bit of wood is what I used.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Mon May 23, 2016 8:57 pm
Looks very much like a piece of left-over Colonial profile skirting from your house renovations. Nice. :)
PostPosted: Tue May 24, 2016 5:51 pm
Haha, it was a sample of the one we didn't use. Interesting point though is that it isn't a hard wood so didn't damage stainless!
Member: VMCI #2474
PostPosted: Thu May 26, 2016 9:23 pm
Thanks all. Yes, I got them off without too much difficulty, small piece of meranti and I used a spatula also to get behind and under the edge. I think though as people have said, getting it on may be more difficult!
PostPosted: Sat May 28, 2016 11:23 am
I am dreading putting my doors back together. I think I stripped them down too far, back to the bare shell but Dr Mini assures me it will all be OK when the time comes!
Member: VMCI #2474
PostPosted: Sat May 28, 2016 12:17 pm
I'm contemplating the getting the painter to put them back on, that way its his responsibility!
