It is currently Mon Jul 28, 2025 2:12 pm
PostPosted: Wed May 18, 2016 1:43 pm
If plating, probably last. You could get the can plated seperately from the cylinder whiley they are apart but it will make it harder solder back on neatly. That said, the plating may not take to the solder that well anyway.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed May 18, 2016 4:42 pm
Thanks Tim
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed May 18, 2016 10:29 pm
Be careful.. I had mine plated but the process ate some of the solder that holds everything together. It lasted a few years but eventually the lids (or at least the little cylindrical bits the lid screw onto) popped off....
Cheers, Ian
PostPosted: Thu May 19, 2016 2:48 pm
They often do that, even when not re-plated. They solder back on pretty easily though.
1955 BSA C11G
1969 Triumph TR6R
Users browsing this forum: Harley and 77 guests
