It is currently Mon Jul 28, 2025 2:14 pm
 Post subject: Valve Resession
PostPosted: Mon May 16, 2016 8:38 pm
Do 940 heads suffer from valve recession when running ulp without a fuel additive? my no 2 exhaust valve stem has severely worn down maybe 1/8 in all the others are fine and clearance settings standard.
1970 Mk 2 Cooper S
 Post subject: Re: Valve Resession
PostPosted: Mon May 16, 2016 8:47 pm
yes they do... but you might have one soft valve stem too?
PostPosted: Mon May 16, 2016 8:49 pm
That's what I was thinking Simon seeing as the others don't appear to have the same issue.
1970 Mk 2 Cooper S
PostPosted: Mon May 16, 2016 9:36 pm
Is the valve sunk into the head, or is the valve stem looking lower when assembled? If the latter, perhaps it has a mk1 exhaust valve there (are 2mm shorter) and 3x oversized 12G940 exhausts.
PostPosted: Mon May 16, 2016 11:38 pm
Valve seat recession will close up your clearances, not make them larger.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Tue May 17, 2016 8:00 am
or poor oiling to the upperworks? hows your oil pump?
PostPosted: Tue May 17, 2016 9:10 am
Stem is definitely worn, oil pressure is fine, will pull the head off and take a look only done around 10000 ml since rebuild, just seems odd that its only one valve. Thanks for the input guys.
1970 Mk 2 Cooper S
PostPosted: Tue May 17, 2016 11:23 am
sounds like one soft valve... the rebuilder or a previous owner might have bought a cheapie to replace a damaged one. If you run a file against the side of the stem tip you'll be able to to tell without taking the head off
limited experience talking, but the best value valves I've come across I bought from minis plus - the online store is in transition, but these are the inlet version... http://www.minisplus.com.au/old-shop/pr ... d-race-ser
send an email to see if he still has the exhaust version
PostPosted: Tue May 17, 2016 6:24 pm
Thanks Simon have run the file over the stem and yes its definitely soft had a burr on one side where the rocker wasn't making contact.
1970 Mk 2 Cooper S
Users browsing this forum: Harley and 82 guests
