It is currently Fri May 10, 2024 3:59 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue May 03, 2011 12:49 pm
ah,,, it was just that i got talking with the boys that make stuff & they suggested that particular material because we`re swinging the crank into 5x thin "pillars" (for want of a better description) for the mains, so wanted some pretty tough stuff for the support & to help reduce the chances of any distortion in that dept. we`re using steel main caps for it tho, & we`re at the stage we`re looking at trying to make a main cap cradle for it, but doesn`t look like we have the room.
i don`t really care what it costs, it`s my little baby & i`ll spoil it all i like :-)
PostPosted: Tue May 03, 2011 6:32 pm
Ah, fair enough... well, you can rest assured that you are in no danger of having any trouble due to the material you've used, Its about as good as ally gets :) It actually has a higher tensile rating than a lot of steels :lol: (and no, that wasn't a joke :shock: )
Yeah I didn't consider that.... most other modern 5 main engines have a fair chunk between cylinders..... seeing as this needs to fit in a mini guess you'd probably need to squish it up so it wouldn't have the support other engines do....
Look forward to seeing this thing rockin and rollin :)
PostPosted: Thu May 05, 2011 8:34 pm
Oi..............step to the other side of the shop and spend some spoiling time on my little baby :lol:
PostPosted: Thu May 05, 2011 9:12 pm
ha ha, hey Ian, good to see you here mate
we`re gonna test this one out in your moke aren`t we??? :-) :-) :-)
Phatty, if you get a chance to see the insides of an R1 case half , then you`ll see what i mean about how tight they are in there :-) :-) :-) so , seeing as the yammys (well all bike case halves i spose) are just cast, well,,, need i say anymore about the strength of mine?
(says that crossing fingers that it doesn`t blow up on the first outing now i`ve said that)
PostPosted: Thu May 05, 2011 11:31 pm
TheMiniMan wrote:
.....Phatty, if you get a chance to see the insides of an R1 case half , then you`ll see what i mean about how tight they are in there :-) :-) :-) so , seeing as the yammys (well all bike case halves i spose) are just cast, well,,, need i say anymore about the strength of mine?
Yeah I know what you're saying, and that's what I meant when I said because you are machining it out of a billet its going to be stronger anyway.... even with out using the same material that NASA use for their space shuttles :) ally castings are always gummy, but they're still strong enough to do the trick... even in turbo charged hayabusa engines putting out 380hp... So if you're using 7075 it will stand up to anything you can do to it without batting an eye lid :)
I haven't seen inside an R1 but I don't see the bores being pitched any wider than a GSXR 1000 or a CBR1000.... its gotta fit sideways in a bike, so it's gotta be tight..... there isn't room for wide pitching....
I just reckon its impressive that you actually bought 7000 series aluminium.... I showed the guys I work with the photo of your billet and their jaws hit the ground too. There just isn't any comparing the strength of this to a cast ally block.... if you have any problems, it won't be because of the material you've chosen :)
PostPosted: Sat Apr 05, 2014 3:33 pm
This is a complete thread mine! I was scrolling through to find my first post and this thread popped up. I remember this idea. Did anything progress miniman??
For all i know there could be another thread on this already :s
1963 850 - laid up
PostPosted: Sun May 24, 2015 2:01 pm
Stopped work on it after a CNC crash, got the other lump of alloy & starting again
waiting for some time on a 5-axis machine, i`ve been grooming a relationship with a friend of mine`s friend
Murwilumbah area will have a full-house race track soon (Hopefully) & the owner of said property has a 5-axis machine & some german guy running it, i`m becoming good buddys with Derick the owner :-)
PostPosted: Sun May 24, 2015 7:59 pm
And lucky for me I am good buddy's with you Matt!!! :wink:
PostPosted: Mon May 25, 2015 11:13 am
Straight from the Edward Lewis school of sucking-up Archangel007
https://www.youtube.com/watch?v=jT5rMvo3Clc
PostPosted: Mon May 25, 2015 4:11 pm
Well lucky for everyone involved it was tongue-in-cheek eh!
PostPosted: Mon May 25, 2015 4:19 pm
:lol:
PostPosted: Mon Jun 08, 2015 11:13 am
Very nice. Its a bit of a crazy project so i hope it doesnt fall off the radar. Love people pushing the envelope!
1963 850 - laid up
PostPosted: Mon Jun 08, 2015 8:24 pm
TheMiniMan wrote:
......a friend of mine`s friend
Murwilumbah area will have a full-house access road (Hopefully) & the owner of said property....
Fixed it for you Matt!
