https://ausmini.com/forums/
RE 1098 pistons
https://ausmini.com/forums/viewtopic.php?f=5&t=96489
Author:  minivan60 [ Tue Dec 19, 2017 5:16 pm ]
Post subject:  RE 1098 pistons
Hi all,I need advise.Im building 0'80" overbored 1098 to my van.I also have a nice 12G202 with bigger valves etc.It's been skimmed and the chamber volume is 24cc.I need to get compression ratio down to 10:1.My question is how much there is meat on top of these pistons? Is it possible machine dishes which are about 5cc?
Tomi
Author:  drmini in aust [ Wed Dec 20, 2017 4:25 am ]
Post subject:  Re: RE 1098 pistons
Don't machine the pistons, open the chambers out around the valves for better breathing.
Edit
And if running 98 fuel you can go to 10.5:1 or so.
Author:  minivan60 [ Wed Dec 20, 2017 5:44 am ]
Thank's for reply.I dont know is there enough metal left for 5cc.I have to check piston to deck height.
Author:  drmini in aust [ Wed Dec 20, 2017 5:48 am ]
You can make those chambers much bigger.
[edit] When decking these old heads it's wise to stop at .075". The deck is thin in places with corrosion and won't clamp the gasket well if you rip more off.
Author:  minivan60 [ Wed Dec 20, 2017 5:54 am ]
Ok.So i leave pistons alone and start to work with head. Thank's Doc.
Tomi
