r53 Gear Shift issues https://ausmini.com/forums/viewtopic.php?f=4&t=95792 |
Author: | MSimpson [ Mon Jul 24, 2017 7:35 pm ] |
Post subject: | r53 Gear Shift issues |
hey all! I have a r53 manual, and the gearshift has had a lot of horizontal play since i bought it. The shifter does not return back to center properly and moves side to side quite a lot even when in gear. I suspect it may be the guide plate but i thought id check with all you'se as to what you think. And a small question to add, all the minis ive seen online have the large center console with a speedo, and the tacometre behind the wheel, but mine has the taco in the center and the speedo behind the wheel. Is this supposed to be a stock option for the 2002 mini s or did the last owners have it swapped for some reason? Appreciate it |
Author: | realmini [ Wed Jul 26, 2017 9:20 am ] |
Post subject: | Re: r53 Gear Shift issues |
The "ball & socket" joint on the gearbox end of the cables often gives trouble, it is a non serviceable part & you have to replace the whole cable. |
