tail light with reversing lights https://ausmini.com/forums/viewtopic.php?f=4&t=100787 |
Author: | Phil 850 [ Mon Feb 22, 2021 2:28 pm ] |
Post subject: | tail light with reversing lights |
In the photo below I have installed tail lights into an 850 shell for a project that I am working on, however the tail lights do not have White Reversing Lights. What model mini has the white reversing lights that fit into the same body housing as these. Attachment: Tail Light 01.jpg Attachment: Tail Light 02.jpg Regards Phil |
Author: | timmy201 [ Mon Feb 22, 2021 3:29 pm ] |
Post subject: | Re: tail light with reversing lights |
There are some on eBay, I can’t tell what specific model they come from Eg https://www.ebay.com.au/itm/MINI-COOPER ... 890.l49292 |
Author: | Phil 850 [ Mon Feb 22, 2021 4:08 pm ] |
Yes, there are lots on eBay, but I need someone that knows for sure that they will fit into the body without modification in place of the current ones I have. |
Author: | ClubmanGT [ Tue Feb 23, 2021 11:15 am ] |
Those lights are from the first generation R50, 02 - 04 which has a single central reverse light on the bumper. 2004/5 saw the facelift R50 released which had the reverse light in the tail light assembly and fog light in place of the central reverse. You need lights from 04-07 (ish) facelift R50. |
Author: | Phil 850 [ Tue Feb 23, 2021 8:28 pm ] |
ClubmanGT wrote: Those lights are from the first generation R50, 02 - 04 which has a single central reverse light on the bumper. 2004/5 saw the facelift R50 released which had the reverse light in the tail light assembly and fog light in place of the central reverse. You need lights from 04-07 (ish) facelift R50. These are listed as R50, R52, R52 2006/6 They look like the same installation as my current ones. Are these the ones you mean ClubmamGT. Attachment: C93A307E-0153-4D49-A783-E5243BD0CD79.jpeg https://www.ecstuning.com/News/MINI_R50 ... 2007_2008/ |
Author: | ClubmanGT [ Wed Feb 24, 2021 2:54 am ] |
Phil 850 wrote: ClubmanGT wrote: Those lights are from the first generation R50, 02 - 04 which has a single central reverse light on the bumper. 2004/5 saw the facelift R50 released which had the reverse light in the tail light assembly and fog light in place of the central reverse. You need lights from 04-07 (ish) facelift R50. These are listed as R50, R52, R52 2006/6 They look like the same installation as my current ones. Are these the ones you mean ClubmamGT. Attachment: C93A307E-0153-4D49-A783-E5243BD0CD79.jpeg https://www.ecstuning.com/News/MINI_R50 ... 2007_2008/ Yes, they are the ones. |
Author: | Phil 850 [ Wed Feb 24, 2021 8:45 pm ] |
Awesome, thanks ClubmanGT |
Author: | Phil 850 [ Fri Feb 26, 2021 8:28 pm ] |
Picked up a pair of tail lights today and the left is a bit hazy. I’ve looked on line and am a bit nervous about using wet n dry on plastic. Everyone recommends it but I’m yet to be convinced. I did use some Maguires Scratch X and it did improve it a bit. Perhaps more elbow grease is required. Any recommendations ? Attachment: DF4B2AC6-103A-48A7-9A55-08B7817AAE64.jpeg
Author: | timmy201 [ Fri Feb 26, 2021 8:31 pm ] |
I used a headlight restoration kit - basically just some fine polish and a polishing attachment that fits in the drill. https://www.autobarn.com.au/mothers-nul ... enewal-kit |
Author: | greyghost [ Sat Feb 27, 2021 7:59 am ] |
use 600 grit wet and dry sandpaper wet, follow up with autosol, then brasso they will come up as good as new, |
