List of Engine Bolts - Anonymous https://ausmini.com/forums/viewtopic.php?f=25&t=84418 |
Author: | Mick [ Sun Feb 02, 2014 4:01 pm ] |
Post subject: | List of Engine Bolts - Anonymous |
This is collated from someone else's hard work from some time ago, I have no idea who it was. Please, if it is yours, or you know who, let me know! But it could be useful from time to time so I will add it here. List of Engine Bolts Timing Cover • 5 x Bolts Cap Head 5/16”UNF (3/4” Long) • 6 x Bolts Cap Head 1/4”UNF (7/16” Long) • 5 x Washers 5/16”PLN (5/8” OD) • 5 x Washers 5/16”SPR (1/2” OD) • 6 x Washers 1/4”PLN (9/16” OD) • 6 x Washers 1/4”SPR (7/16” OD) • 1 x Nut 5/16”UNF (1/2” Head) • 1 x Nut 1/4”UNF (7/16” Head) Coolant Circuit • 2 x Bolts Heater Tap 1/4” UNF (7/16” Head, 1/2” Long) • 2 x Washers Heater Tap 1/4” SPR (3/8” OD) • 2 x Bolts Radiator Top 1/4” UNF (7/16” Head, 1 1/2” Long) • 2 x Washers Radiator Top 1/4”PLN (9/16” OD) • 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 2” Long) • 2 x Bolts (Water Pump) 5/16”UNF (1/2” Head, 1” Long) • 4 x Washers (Water Pump) 5/16”PLN (5/8” OD) • 4 x Washers (Water Pump) 5/16”SPR (1/2” OD) Thermostat (Short) • 3 x Bolts 5/16 UNC (1/2” Head, 1 1/2” Long) • 3 x Washers 5/16” SPR (1/2” OD) Engine Electrical • 2 x Bolts (Alt’ top) 5/16”UNF (1/2” Head, 2” Long) • 1 x Bolt (Alt’ Bottom) M8x20 • 1 x Nut (Alt’ Bottom) M8 NyLoc • 4 x Washers (Alternator) 5/16”PLN (5/8” OD) • 4 x Washers (Alternator) 5/16”SPR (1/2” OD) • 2 x Nuts (Alternator) 5/16”UNF (1/2” Head) • 2 x Bolts Starter Motor 3/8”UNC (9/16” Head, 1 1/4” Long) • 2 x Washers Starter motor 3/8”SPR (5/16” OD) • 1 x Bolt (A+ Distributor) 5/16” UNF (1/2” Head, 3/4” Long) Clutch Slave (Non verto) • 2 x Bolts (Cyl Mount) 3/8”UNC (9/16” Head, 1” Long) • 2 x Washers (Cyl Mount) 3/8”SPR (5/8” OD) • 1 x Bolt (Arm Stop) 1/4”UNF (7/16” Head, 1” Long) • 1 x Lock Nut (Arm Stop) 1/4”UNF (7/16” Head) Clutch Cover • 8 x Bolts 5/16”UNC (1/2” Head, 1” Long) • 8 x Washers 5/16”SPR (1/2” OD) • 8 x Washers 5/16”PLN (5/8” OD) Tappet Chest • 2 x Bolts 5/16” UNF (1/2” Head, 1 1/4” long) • 2 x Washers 5/16 PLN (5/8” OD) Pre A+ Distributor Drive • 1x Bolt 1/4”UNF (7/16” Head, 3/4” long) • 1x Washer 1/4”SPR (3/8” OD) Fuel Pump • 2 x Bolt 5/16” UNC (1/2 Head , 1 1/2”long) • 2 x Washers 5/16” SPR (1/2” OD) • 2 x Washers 5/16” PLN (5/8” OD) Oil Filter Housing • 2 x Bolt 3/8” UNC (9/16” Head, 1” Long) • 2 x Washers 3/8” SPR • 2 x Washers 3/8”PLN (15/16” OD) Manifold Bolts • 6 x Bolt 5/16 UNF (1” Long) • 6 x Washers 5/16” SPR (1/2” OD) • 6 x Washers 5/16” PLN (5/8” OD) |
