DIY Dents, Rust, Bog and Paint Touch up by Phat Kat https://ausmini.com/forums/viewtopic.php?f=25&t=60141 |
Page 4 of 5 |
Author: | adamstuart [ Mon Jan 11, 2010 5:02 pm ] |
MiniKit wrote: I've done the heat/ rapid cooling method on a dinner plate sized dent on the roof it popped out really well, but I wasn't concerned about the paint and was using a heat gun. What did you use to cool it, and where did you get it? |
Author: | Phat Kat [ Mon Jan 11, 2010 9:55 pm ] |
adamstuart wrote: MiniKit wrote: I've done the heat/ rapid cooling method on a dinner plate sized dent on the roof it popped out really well, but I wasn't concerned about the paint and was using a heat gun. What did you use to cool it, and where did you get it? While you're waiting for MiniKit to come back, I can tell you how I've done it? You get a heat gun (like a blow drier,,, an EXTREME BLOW DRIER!!!!) and a hammer. You push firmly under the dent in the middle usually (but don't put your weight into it, just firm is all it needs,,, about enough that the panel is juuuuust about to flex) using the butt of the hammer handle and heat the whole dent. Eventually it "pops" back to shape It works well on plastic bumpers as well. If you are doing a dent bigger than the your hand print I would suggest using a block of 4X2 instead so that you don't stretch the panel. . . . I should point out again that this does not work on all types of dents . . . I'm interested to hear about Minikit's method too, it sounds like the "Paintless dent removal" that you hear about with the smash repair guys talk about. |
Author: | MiniKit [ Tue Jan 12, 2010 12:58 am ] |
wasn't too hard. I've done it twice now once on the driver's side front quarter but the first time was on the roof. When I first got my mini there were a few spots of bog with cracks in it. After removing all the paint from the roof there was a massive dent right in the middle. I wouldn't say somebody had sat on it but it was pretty damn close. Whoever did the first repair pushed it out as best they could and I tried also. I'd push it up and it would stay there for about 5 deconds before becoming concave again. I had a chest freezer at the time. I filled a bucket of water up and left in there until it was icy cold. I heated up the dent for what seemed like ages, but in reality it was only about 8 minutes, moving the heat gun over the area. I had a helper and while I was doing the heat gun thing I asked them to get the bucket of water, they came back and I handed him the heat gun as he passed me the bucket of water and I threw it over the roof. It made a "PONG" kind of noise and popped out.. But I've also heard of wet towels working, anything really, but whatever it is has to get the heat out of the panel damn quick.. ![]() Also if you want to see other people doing it go to you tube and search for paintless dent removal. |
Author: | norton [ Tue Jan 12, 2010 8:31 am ] |
This is impressive PDR http://www.youtube.com/watch?v=HhT79ZXU ... re=related There are a heap of vids like it also the heat gun method check them out |
Author: | Phat Kat [ Tue Jan 12, 2010 8:33 am ] |
Awesome MiniKit ![]() I found this this morning on Youtube http://www.youtube.com/watch?v=q0UAUBE-Hmg Very similar to what your talking about expcet they use Co2 instead of ice. I'm really suprised to hear it worked on a mini, you see it done on new cars all the time because they are made out of a flimsy guage of steel. I'll give it a wirl on a donar and come back with pic's. Cheers ![]() |
Author: | norton [ Tue Jan 12, 2010 9:10 am ] |
I heard that some new cars are using high tensile steel in some panels, I am guessing they would retain there memory better than mild steel and pop back easier using these PDR and heat cold methods |
Author: | adamstuart [ Tue Jan 12, 2010 11:52 am ] |
Where does one obtain a can of CO2? Bunnings...? |
Author: | awdmoke [ Tue Jan 12, 2010 11:57 am ] |
Dick Smiths, Jaycar Electronics, etc |
Author: | Phat Kat [ Tue Jan 12, 2010 12:15 pm ] |
I just gave it a wirl on a mini,, what I found was.... It works on flat panels where there is little stretching. It does not work on panel shapes with tight curves It does not work on panels already covered in bog It does not work on rusted panels . . . MiniKit, I couldn't get the panel hot enough with out burning the paint... you said Quote: I wasn't concerned about the paint and was using a heat gun.
Did you end up burning the paint? . . . On newwer cars, with thinner panels you don't need to get them as hot (hence why you can use a blow drier) |
Author: | MiniKit [ Tue Jan 12, 2010 6:11 pm ] |
Oh yeah toasted it good and proper. ![]() I had removed all the bog first on the roof.... I'm currently working on a dent puller made out of an old suspension shocky out of a washing machine too. Cheap and disposeable.. I'll post up some pics if it works, and, if anyone is interested of course.. |
Author: | winabbey [ Tue Jan 12, 2010 6:51 pm ] |
MiniKit wrote: ... made out of an old suspension shocky out of a washing machine.
Removes the dent and washes the car at the same time - what a great idea!! ![]() |
Author: | Monaco [ Mon Jan 18, 2010 5:48 pm ] |
This is one of the best threads I have read! Great advice, any chance of some spraying instructions for two pack? |
Author: | Phat Kat [ Mon Jan 18, 2010 6:09 pm ] |
owen1975richard wrote: This is one of the best threads I have read! Great advice, any chance of some spraying instructions for two pack?
Thanks owen1975richard, glad you like it. 2k is great, in that it lasts longer than acrylic, it's harder to chip, harder to scatch, it doesn't fade as quickly, its a little less labourious to apply (doesn't require compounding.. but it can be), it tolerates UV light better... there are a lot of advantages. BUT I'm sorry mate, I won't teach people to use it. You need to use it in a spray booth and you need to use an Air Fed face sheld, and a sealed suit. It is Leathal stuff. It is illegal to use it at home. As it, Acrylic is only barely legal to use at home. . . . Sorry mate. Happy to tell you anything you want to know about Acrylic, but no 2k. This is a thread I previously put up, teaching acrylic if your interested http://www.ausmini.com/forums/viewtopic ... 0&start=75 EDIT: If you need to know about the effects of using it without proper safety gear, just ask micowen. He'll tell you allllllll about it. |
Author: | Phat Kat [ Sat Jun 12, 2010 9:40 am ] |
![]() ![]() ![]() How did this thread end up here? It started in Mini Chat? It doesn't belong her.... |
Author: | Kennomini [ Sat Jun 12, 2010 10:42 pm ] |
I agree, I don't see what body repairs has to do with engine mods ![]() Perhaps it needs to be moved to the "how to" section so it doesn't get lost 500 pages deep in mini chat section, that's the only reason I can see why it was moved here. |
Page 4 of 5 | All times are UTC + 10 hours |
